cam install now car won't rev w/video!!
So the car won't rev past 3500 rpm. It idles smooth as you can hear, under the hood is quiet, no ticking, so I know the valve lash is good (did just over half a turn for preload on 1.6R rollers w/poly locks). No vacuum leaks. I had the K&N off in the video, but with it on there is no noise.
http://www.youtube.com/watch?v=1txNvVlRfwQ
What could the problem be? It seems like a fuel issue, the car won't go past a certain rpm. Or does it sound like the timing is off? I'm almost positive I had it perfect when I put the timing cover on. It wouldn't be a lot of work to pull it off and have a look, but I dont wanna pay 20 for another gasket set.
I was told that it would adjust to the mods, so I planned on getting my spare pcm tuned in a couple weeks. I have not checked the fuel pressure.
I did heads/cam/30# injectors.
I set the valve lash 3 times, quadruple checked for vac. leaks, and rechecked all the plug wires twice. I'm totally stumped.
I'm going to check the plug wires again tomorrow. I might pull the injectors too if I don't find a problem with the plugs. I bought the 30#'s used, so they could be faulty.
Well, I only did a half turn, if this is a half turn....
Is that correct? I marked the nut at 12 oclock when I reached zero lash, then i tightened it to 6 oclock. Is this correct, or is that not a half turn? I've never adjusted rockers until yesterday.
It should rev out w/o a tune.
Your lash is correct based on your description.
What happens if you actually try to drive it as opposed to just revving in the driveway. I can't really hear it very well in the video...
Try disconnecting your O2's.
