Any good shop for LTX base f-body near...
MODERATOR:Im posting this here because im searching for a good LT1/LT4 shop not a LS1 specialist that do LTX base car once every year
But if you think its the wrong forum just move it.Thank you.
I need a good shop for my LT4 firebird near Champlain NY 12919 or Montreal(im at 30mins from Champlain).I need a serious shop that can do some troubleshooting for my problem, fix them and probably do some tuning.
I dont wanna shop that does ltx base f-car only once in a while because i dont wanna hear something like:"i think this is your problem but im not sure"
So what are my option.I spent more than 15k in that car in the last 2 years and it still doenst run good so its time to bring it to some pro
Thank you
But if you think its the wrong forum just move it.Thank you.I need a good shop for my LT4 firebird near Champlain NY 12919 or Montreal(im at 30mins from Champlain).I need a serious shop that can do some troubleshooting for my problem, fix them and probably do some tuning.
Thank you
Nothing crazy just a fun and reliable setup:
CAR:
1995 Firebird formual silver/black top,6 speed,t-top,leather
MOTOR/IGNITION:
-Brand new 96 LT4 GM crate motor with plastic valve cover
-New GM lt1 oil pan
-96 LT4 GM intake
-New Delphi 32lbs injectors
-New Delco optispark distributor
-New msd blaster coil
-New taylor spiro wire otvc side mount
-New tr55 ngk plug
-Moroso CAI
-Brand new crank hub
-Brand new ASP crank pulley
-New rebuilt and ported(52mm) stock throttle body to avoid sticking blade with ported air foil
-New knock sensor
-New oxygen sensor(on both side with new pass side O2 extension)
-New coolant sensor(both: on head to gauge and on water pump to ecm)
-New oil pressure sensor with new angle fitting
-New throttle cable(no traction control)
-New rebuilt stock water pump
-New power steering pump
-New poly motor mount(2)
-New A/C delete pulley
-New dipstick tube and dipstick
-New pcv
-New IAC
-ALL NEW gasket for everything(water pump,intake,steam pipe,TB,etc...)
EXAUST:
-New Kooks custom stainlees steel headers(1 3/4" primary to 3" collector)
-New Kooks custom stainless "y" pipe no cats(3")
-Magnaflow stainless steel cat back
-Accessories:stainless band clamp,1406 headers gasket,1" 12pt stainless steel headers bolts
CLUTCH/DRIVELINE:
-New RAM HDX clutch kit ,with new master cylindre and new oem pressure plate bolts
-Stock resurfaced flywheel(oem first time) with new oem flywheel bolts
-New pilot bushing
-Spohn chromoly HD driveshaft with spicer yoke and 1350 u-joint
-Strange 12 bolts,hd posi,33splines,3.73 gear with LPW cover with preloads caps
SUSPENSION/CHASSIS:
-Koni SA adjustable shock on stock spring
-Stranos 35mm front Hollow sway bar with poly bushing and end link
-Stranos 22mm rear hollow sway bar with poly bushing and end link
-Strut brace
-Welded subframe connector
-UMI tubular adjustable rear control arm(poly/rod end)
-UMI tubular adjustable panhard rod(poly/rod end)
-Spohn adjustable torqe arm tunnel brace mount(poly bushing)
BRAKE:
-C5 brake kit conversion
-Braided lines
-Hawks hps brake pads(4 corner)
-18"X9.5" all black ZR1 wheel
-285/35zr18 Falken GRB FK-451
MISC:
-Tune pcm by MADZ28 with lt4 knock module
-WS6 store 6.5" short stick with hurst leather shift ****
-MBA stainless steel gauge bezel
-MBA aluminium black radiator shroud cover
-ABS delete/TCS delete/AC delete/AIR delete
-Tuner cat with laptop
-FAST wideband double bank with rpm module kit
CAR:
MOTOR/IGNITION:
-New GM lt1 oil pan
-96 LT4 GM intake
-New tr55 ngk plug
-Moroso CAI
-New knock sensor
-New pcv
-New IAC
EXAUST:
CLUTCH/DRIVELINE:
-New pilot bushing
SUSPENSION/CHASSIS:
-Strut brace
BRAKE:
-Braided lines
MISC:
hmm.. just wondering. My all_ignition one was defective out of the box. Did all kinds of weird crap including run like crap and eat fuel like crazy. ummm. Have you tried loading a stock LT4 tune and see what happens?
I diddnt found a stock lt4 tune but i ve tried a stock lt1 tune calibrate for my 32 injectors and no change at all.
