Any good shop for LTX base f-body near...
Old Aug 1, 2007 | 07:41 AM
always faster's Avatar
MODERATOR:Im posting this here because im searching for a good LT1/LT4 shop not a LS1 specialist that do LTX base car once every year But if you think its the wrong forum just move it.Thank you.
I need a good shop for my LT4 firebird near Champlain NY 12919 or Montreal(im at 30mins from Champlain).I need a serious shop that can do some troubleshooting for my problem, fix them and probably do some tuning.
I dont wanna shop that does ltx base f-car only once in a while because i dont wanna hear something like:"i think this is your problem but im not sure"
So what are my option.I spent more than 15k in that car in the last 2 years and it still doenst run good so its time to bring it to some pro
Thank you
Old Aug 1, 2007 | 07:50 AM
sabre81's Avatar
hmmm. whats the problem? I read your post about hesitation problems. Is that it?
Old Aug 1, 2007 | 02:17 PM
Well yeah the car hesitate,from the datamaster files it run lean and the pcm try to compensate but it make it run to rich.
Also i got knock all over the rpm band.
And im tired now
Old Aug 1, 2007 | 02:20 PM
96ZCamaro's Avatar
What mods is it you have though.
Old Aug 1, 2007 | 02:36 PM
Nothing crazy just a fun and reliable setup:
CAR:
1995 Firebird formual silver/black top,6 speed,t-top,leather
MOTOR/IGNITION:
-Brand new 96 LT4 GM crate motor with plastic valve cover
-New GM lt1 oil pan
-96 LT4 GM intake
-New Delphi 32lbs injectors
-New Delco optispark distributor
-New msd blaster coil
-New taylor spiro wire otvc side mount
-New tr55 ngk plug
-Moroso CAI
-Brand new crank hub
-Brand new ASP crank pulley
-New rebuilt and ported(52mm) stock throttle body to avoid sticking blade with ported air foil
-New knock sensor
-New oxygen sensor(on both side with new pass side O2 extension)
-New coolant sensor(both: on head to gauge and on water pump to ecm)
-New oil pressure sensor with new angle fitting
-New throttle cable(no traction control)
-New rebuilt stock water pump
-New power steering pump
-New poly motor mount(2)
-New A/C delete pulley
-New dipstick tube and dipstick
-New pcv
-New IAC
-ALL NEW gasket for everything(water pump,intake,steam pipe,TB,etc...)
EXAUST:
-New Kooks custom stainlees steel headers(1 3/4" primary to 3" collector)
-New Kooks custom stainless "y" pipe no cats(3")
-Magnaflow stainless steel cat back
-Accessories:stainless band clamp,1406 headers gasket,1" 12pt stainless steel headers bolts
CLUTCH/DRIVELINE:
-New RAM HDX clutch kit ,with new master cylindre and new oem pressure plate bolts
-Stock resurfaced flywheel(oem first time) with new oem flywheel bolts
-New pilot bushing
-Spohn chromoly HD driveshaft with spicer yoke and 1350 u-joint
-Strange 12 bolts,hd posi,33splines,3.73 gear with LPW cover with preloads caps
SUSPENSION/CHASSIS:
-Koni SA adjustable shock on stock spring
-Stranos 35mm front Hollow sway bar with poly bushing and end link
-Stranos 22mm rear hollow sway bar with poly bushing and end link
-Strut brace
-Welded subframe connector
-UMI tubular adjustable rear control arm(poly/rod end)
-UMI tubular adjustable panhard rod(poly/rod end)
-Spohn adjustable torqe arm tunnel brace mount(poly bushing)
BRAKE:
-C5 brake kit conversion
-Braided lines
-Hawks hps brake pads(4 corner)
-18"X9.5" all black ZR1 wheel
-285/35zr18 Falken GRB FK-451
MISC:
-Tune pcm by MADZ28 with lt4 knock module
-WS6 store 6.5" short stick with hurst leather shift ****
-MBA stainless steel gauge bezel
-MBA aluminium black radiator shroud cover
-ABS delete/TCS delete/AC delete/AIR delete
-Tuner cat with laptop
-FAST wideband double bank with rpm module kit
Old Aug 1, 2007 | 02:38 PM
sabre81's Avatar
what brand of o2's? ..
anddd didn't i see in another port that you were running an opti from all_ignition ?
Old Aug 1, 2007 | 02:43 PM
AC/DELCO o2 sensor
And yeah im running a all ignition opti.And this is not a problem.I ve tried 4 opti(2 msd,2 ac/delco)and all those problem are still there.
Old Aug 1, 2007 | 02:45 PM
sabre81's Avatar
hmm.. just wondering. My all_ignition one was defective out of the box. Did all kinds of weird crap including run like crap and eat fuel like crazy. ummm. Have you tried loading a stock LT4 tune and see what happens?
Old Aug 1, 2007 | 02:49 PM
I diddnt found a stock lt4 tune but i ve tried a stock lt1 tune calibrate for my 32 injectors and no change at all.
Old Aug 1, 2007 | 02:54 PM
sabre81's Avatar
hmm.. so it can't be pcm related. hmmmmmmmmmmmmmmmmmm. how's fuel pressure? how old is your fuel pump?
Old Aug 1, 2007 | 02:55 PM
Pressure has been test a couple of times and its perfect.The has also less than 6000miles.
Old Aug 1, 2007 | 02:56 PM
sabre81's Avatar
no trouble codes right?
Old Aug 1, 2007 | 02:57 PM
That would be too easy
No code
Old Aug 1, 2007 | 03:06 PM
sabre81's Avatar
could i take a look at the datamaster file?
Old Aug 1, 2007 | 03:08 PM
Shoot me your email buddy
