Opinions on Lunati Voodoo #60121?
I've been looking around for some opinions on this cam on various sites and it doesnt seem like many ppl have discussed the voodoo cams much. The specs on this cam are as follows:
Advertised Duration IN/EX: 270/278
Duration @ .050 IN/EX: 221/229
Gross Valve Lift IN/EX: .515/.530
LSA / ICL: 112/106
RPM Range: 1800-5800
My car has an Edge 3000 stall converter, 3.73 gears, CAI & catback exhaust. It still has the stock manifolds and cat converter on it and I dont plan to change this anytime soon.
Has anyone used this cam or known anyone who has? I'm curious how it sounds and how well it does in the low/mid range power band.
LSA / ICL: 112/106
i believe that cam actually peaks at like 6200 IIRC, i called lunati once and asked about it, but i decided to go w/ a LPE cam. That cam will work nice too. Are those lift #'s with 1.5s or 1.6s, i believe those are w/ 1.5's, correct?
Thanks for the responses
yeah the lift #'s are for 1.5rr's
I agree that those springs do look a bit weak, but thats what they recomend. I was going to get the comp 918's but after reading about their problems the last few months I think I'll pass. If lunati recomends these springs then I hope they're good enough
for lifters though, I ordered the comp 850's.
yeah the lift #'s are for 1.5rr'sI agree that those springs do look a bit weak, but thats what they recomend. I was going to get the comp 918's but after reading about their problems the last few months I think I'll pass. If lunati recomends these springs then I hope they're good enough
I didn't notice it before, but your numbers are off a bit on the cam specs.
http://www.holley.com/data/Products/Technical/60121.pdf
As far as comparison to the 503:
Overlap/IVC
503 54.5/66
60121 50/61
The Lunati cam has less overlap and an earlier IVC. I believe this means that it would work better with stock motors as it provides higher DCR. Not sure if that's a great thing or not, considering the very high quench that the stock LT1 has. Generally, with more overlap you get more hp in upper rpm, but at the loss of lower end torque, IIRC.
The Lunati cam also has 6 degrees of advance ground into the cam, instead of 4 degrees like the 503 and most other LT1 cams. I think it all means that the Voodoo cam would be more of a torque monster, but may not have the punch of the 503 at higher rpm. Don't know until you try it!
Overlap/IVC
503 54.5/66
60121 50/61
eh that torque looks kinda low man, my stock LT1 with just a tune, CAI and SLP catback exhaust made 347ft lbs of torque and thats thru the stock manifolds and cat converter.
http://s6.photobucket.com/albums/y21...=dynosheet.jpg
I just ordered a scat 383 rotating assembly and I'll cry if my setup dyno's below what my stock LT1 did
even if the hp is much higher
From what I've read, Bret Bauer is a great person to go to for a custom cam, expecially with an oddball setup. So since I'll still be using stock heads and manifolds, I may check out his prices instead of going with a Lunati cam.
even if the hp is much higherFrom what I've read, Bret Bauer is a great person to go to for a custom cam, expecially with an oddball setup. So since I'll still be using stock heads and manifolds, I may check out his prices instead of going with a Lunati cam.
Yup your dyno put down more torque but look at where it did that. By 4000rpms your already below 300ftlbs and droping fast. Im sure if my converter didnt flash so high I would of had a much higher torque output as well. The other looks like you sprayed it. Its not about peak numbers, its all about the curve, and useable power. I bought the T/A blown up, I built the motor and had the tranny. Total cost to build the motor including springs, cam, rockers and bottom end was less then $1800.
My car with the stock motor had absolutely no ***** from a roll, but it would launch hard as hell. Hopefully with the new motor it'll feel better throughout the rpm range.
