Shift light install questions
Hey guys
I'm installing a shiftlight into my car, standard power/ground/tach style
I'm having trouble finding a good power wire under my dash, does anyone have a good description of where one is, needs to be a 12 volt that comes on with the ignition.
I've also heard that theres a tach wire coming off the coil, which wire is it? My plug into it has two wires, one appears to be orange, the other a pinkish color.
Thanks for any help
Thanks for any help
I found a ground screw in my chassis and ran the ground wire for my shift light to that, there are grounds everywhere.
For the power source I used a single blade connector and put it in the part of the interior fuse panel labeled "ign" or something like that. It's a switched source and is quite effective for what you're looking for without having to splice wire.
As for the tach signal, I used the white(?) wire going from the PCM under the passenger side kick panel.
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
