Shift light install questions
Old Jun 24, 2007 | 03:23 PM
urbaNHunter44's Avatar
Hey guys
I'm installing a shiftlight into my car, standard power/ground/tach style
I'm having trouble finding a good power wire under my dash, does anyone have a good description of where one is, needs to be a 12 volt that comes on with the ignition.
I've also heard that theres a tach wire coming off the coil, which wire is it? My plug into it has two wires, one appears to be orange, the other a pinkish color.
Thanks for any help
Old Jun 24, 2007 | 03:33 PM
SS1156's Avatar
What kind of shift light?
Old Jun 24, 2007 | 03:47 PM
summit brand
Old Jun 24, 2007 | 04:13 PM
reamo04's Avatar
12v under ignition - lets see, fuel pump, radio just to name a few. Think of things that come on when u turn ur key "on"
Old Jun 24, 2007 | 04:55 PM
I used the pink wire coming off the ASR switch for the power, now just to find a good ground..
Old Jun 24, 2007 | 06:45 PM
Ratlor's Avatar
I found a ground screw in my chassis and ran the ground wire for my shift light to that, there are grounds everywhere.
For the power source I used a single blade connector and put it in the part of the interior fuse panel labeled "ign" or something like that. It's a switched source and is quite effective for what you're looking for without having to splice wire.
As for the tach signal, I used the white(?) wire going from the PCM under the passenger side kick panel.
Old Jun 24, 2007 | 09:49 PM
For future searchers, I used the White wire coming out of the red connector on the PCM, I used the power wire from the ASR switch and I used the ground off my radio.
blac94Z
Jan 12, 2015 05:44 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
