383 Stall
383 Stall
I am building a 383 stroker and im running low on funds for it
. I want to get a converter that has a stall around 2800. What do you guys recomend as a good one. Keep in mind im low on cash. FYI I already purchased a shift kit. I also plan on installing a 150 shot in the future.
cheap = breaks. save some cash and get a good stall. it really sucks to drive for 3,000 miles then have a lockup clutch come apart ruining your converter and your transmission. then you're stuck tearing out the transmission, having it rebuilt, and buying a new converter.
spend a little more now, or spend ALOT more later.
I dont even think these will fit but ill use them as an example. Do you think the converters in the link are crap?
http://www.jegs.com/webapp/wcs/store...50793_-1_10555
really. Its one of those things that you dont want to, but you just got to. I dont want to put the stock converter back it. Thats just going to suck having to launch at 1700 rpms. Im going to have to sleep on this one
And by the way, are you a former Eclipse owner? DSM?
I know how you feel man. I had the same dilemma. The converter and gears are whats going to make a night and day difference in your ride. Dont skimp on those if your going all out with the 383. You do that 383 and put that stock converter in your still going to enjoy the power, but when you finally put a quality converter in your going to kick yourself for not doing it earlier.
what you guys think about this one
Street Series
The Street Series converters are a great lower priced alternative to the Performance and HP/Street Series converters. These converters will wake up your setup and are a good choice for a solid boost in acceleration.
Click Here for more info
S . 2400
2400 Stall Speed
1.7 STR
http://www.fuddleracing.com/298.html#S%20298
Street Series
S . 2400
2400 Stall Speed
1.7 STR
