I Need Timing Chain Help
im building a new lt1 with an electric wp. this is a 94 style setup and has a 94 cover. What timing chain should i be using that is the most cost effective. Ive done the searches but they dont help me with which one i should use. Thanks alot for any input
I used a set made by s.a. gear out of chicago Ill. You can order it from parts america online. it was 130.00 . and it was made in the U.S.A. . Be very carefull of junk being sold on ebay.
They might, but I am not sure Cloyes even makes a stock type set for unvented optis in the aftermarket. Though, I think the stock set may actually be made by Cloyes. They make a lot of GMs stuff.
It's the non-vented opti that is now keeping you from other choices. People with vented optis only have to change to an EWP to be able to use other types of timing sets. You still have to drive the non-vented opti with the stock type cam gear.
