I Need Timing Chain Help
Old Apr 16, 2007 | 08:56 AM
xxxtreme36's Avatar
im building a new lt1 with an electric wp. this is a 94 style setup and has a 94 cover. What timing chain should i be using that is the most cost effective. Ive done the searches but they dont help me with which one i should use. Thanks alot for any input
Old Apr 16, 2007 | 11:09 AM
Unless you convert to a vented opti, you are virtually stuck with having to use a stock timing set.
Old Apr 16, 2007 | 02:38 PM
xxxtreme36's Avatar
oh thats fine, im just wondering what the replacement part number would be for a cloyes or something of that sort
Old Apr 16, 2007 | 03:16 PM
ayers1967's Avatar
I used a set made by s.a. gear out of chicago Ill. You can order it from parts america online. it was 130.00 . and it was made in the U.S.A. . Be very carefull of junk being sold on ebay.
Old Apr 16, 2007 | 03:25 PM
They might, but I am not sure Cloyes even makes a stock type set for unvented optis in the aftermarket. Though, I think the stock set may actually be made by Cloyes. They make a lot of GMs stuff.
Old Apr 17, 2007 | 08:42 AM
xxxtreme36's Avatar
so i even have to use a stock replacement if not using a conventional stock wp???
Old Apr 17, 2007 | 09:50 AM
It's the non-vented opti that is now keeping you from other choices. People with vented optis only have to change to an EWP to be able to use other types of timing sets. You still have to drive the non-vented opti with the stock type cam gear.
Old Apr 17, 2007 | 12:39 PM
xxxtreme36's Avatar
ok i understand what your saying, so who or where would be the best place to get a stocker??
Old Apr 17, 2007 | 12:44 PM
94_PatriotRed_Z's Avatar
I got a stock replacement from the dealership for $135 a month ago, but that was with a 10% student discount I think it was $150 without the discount
Old Apr 17, 2007 | 12:51 PM
jeepbeast's Avatar
gmpartsdirect.com.
just got mine a bit ago, i think it was around 100 for the chain, cam sprocket, crank sprocket.
you can get the part numbers on shoebox's site
Old Apr 18, 2007 | 02:38 PM
xxxtreme36's Avatar
any ideas on who i could a decent gasket kit from? all gaskets? part num?
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
