Cam swap question
Cam swap question
I plan on a cam swap in the next month and I was wondering how this set-up sounds. I plan on ording my parts from summit.
CCA-07-503-8 Camshaft, Hydraulic Roller Tappet, Advertised Duration 276/281, Lift .503/.510, Chevy, LT1/LT4, Each
$255.95
CCA-1305-16 Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 7/16 in. Stud, Chevy, Small Block, Set of 16
$275.95
CCA-26918-16 Valve Springs, Single, 1.055 in. Outside Diameter, 313 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16
$185.95
CCA-4501-16 Rocker Arm Studs, 7/16-20 in. Thread, 1.75 in. Effective Stud Length, Kit
$42.99
CCA-4705-16 Valve Spring Locators, Inside, Steel, .060 in. Thick, 1.100 in. O.D., .650 in. I.D., .660 in. Spring I.D., Set
$41.99
CCA-614-16 Valve Locks, Machined, Hardened Steel, 10 Degree, 1-Groove, 11/32 in. Valve Stem, Set of 16
$26.95
CCA-7808-16 Pushrods, High Energy, Steel, Heat Treated, 5/16 in. Diameter, 7.195 in. Length, Universal, Set of 16
$35.88
CCA-795-16 Valve Spring Retainers, Steel, 10 Degree, 1.095 in. Outside Diameter, .640 in. Inside Diameter, Set of 16
$50.69
FEL-MS95580 Gaskets, Manifold, Intake, Stock Port, LT1 Chevy, 5.7L, Set
$21.99
FEL-TCS45956 Gaskets, Timing Cover, Chevy, Small Block, Kit
$15.99
SUM-G6450 Guideplates, Flat, 5/16 in. Pushrod Size, Chevy, Small Block, Set of 8
$14.95
$255.95
$275.95
$185.95
$42.99
$41.99
$26.95
$35.88
$50.69
$21.99
$15.99
$14.95
If these are on stock LT1 heads, get the 10 degree + .050" locks and retainers.
DON'T USE THOSE GUIDEPLATES. Only use either the GMPP or Isky adjustable guideplates.
Also make sure that whomever you're ordering those springs from that they were involved with the recall from Comp Cams and sent back any bad sets.
More than likely they won't align the pushrods correctly. The correct ones aren't that expensive. Why leave something like that to chance?
Get some good chromemoly .080" wall one-piece pushrods. Comp, Crane, Manley, Thunder and Trickflow all have good ones.
Updated list. Does this sound better?
$255.95
$275.95
$185.95
$42.99
$41.99
$26.95
SUM-1457200 Pushrods, Chromemoly, Heat Treated, 5/16 in. Diameter, 7.200 in. Length, Universal, Set of 16
$80.95
$50.69
$21.99
$15.99
NAL-14011051 Guideplate, Flat, 5/16 in. Pushrod Size, Chevy, Small Block, Each
$4.88
$255.95
$275.95
$185.95
$42.99
$41.99
$26.95
$80.95
$50.69
$21.99
$15.99
$4.88
