Cam swap question
Old Apr 11, 2007 | 05:41 PM
red1984's Avatar
Cam swap question
I plan on a cam swap in the next month and I was wondering how this set-up sounds. I plan on ording my parts from summit.
CCA-07-503-8 Camshaft, Hydraulic Roller Tappet, Advertised Duration 276/281, Lift .503/.510, Chevy, LT1/LT4, Each
$255.95
CCA-1305-16 Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 7/16 in. Stud, Chevy, Small Block, Set of 16
$275.95
CCA-26918-16 Valve Springs, Single, 1.055 in. Outside Diameter, 313 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16
$185.95
CCA-4501-16 Rocker Arm Studs, 7/16-20 in. Thread, 1.75 in. Effective Stud Length, Kit
$42.99
CCA-4705-16 Valve Spring Locators, Inside, Steel, .060 in. Thick, 1.100 in. O.D., .650 in. I.D., .660 in. Spring I.D., Set
$41.99
CCA-614-16 Valve Locks, Machined, Hardened Steel, 10 Degree, 1-Groove, 11/32 in. Valve Stem, Set of 16
$26.95
CCA-7808-16 Pushrods, High Energy, Steel, Heat Treated, 5/16 in. Diameter, 7.195 in. Length, Universal, Set of 16
$35.88
CCA-795-16 Valve Spring Retainers, Steel, 10 Degree, 1.095 in. Outside Diameter, .640 in. Inside Diameter, Set of 16
$50.69
FEL-MS95580 Gaskets, Manifold, Intake, Stock Port, LT1 Chevy, 5.7L, Set
$21.99
FEL-TCS45956 Gaskets, Timing Cover, Chevy, Small Block, Kit
$15.99
SUM-G6450 Guideplates, Flat, 5/16 in. Pushrod Size, Chevy, Small Block, Set of 8
$14.95
Old Apr 11, 2007 | 06:57 PM
seawolf06's Avatar
If these are on stock LT1 heads, get the 10 degree + .050" locks and retainers.
DON'T USE THOSE GUIDEPLATES. Only use either the GMPP or Isky adjustable guideplates.
Also make sure that whomever you're ordering those springs from that they were involved with the recall from Comp Cams and sent back any bad sets.
Old Apr 11, 2007 | 10:24 PM
red1984's Avatar
Why shouldn't I use the SUM-G6450 Guideplates?
Old Apr 11, 2007 | 10:49 PM
seawolf06's Avatar
More than likely they won't align the pushrods correctly. The correct ones aren't that expensive. Why leave something like that to chance?
Get some good chromemoly .080" wall one-piece pushrods. Comp, Crane, Manley, Thunder and Trickflow all have good ones.
Old Apr 12, 2007 | 08:33 AM
Z-RATED94's Avatar
Because the spacing of the pushrods is wrong for LTx heads. GMPP or the Iskys as seawolf06 mentioned is the way to go.
Old Apr 16, 2007 | 03:03 PM
red1984's Avatar
Updated list. Does this sound better?
$255.95
$275.95
$185.95
$42.99
$41.99
$26.95
SUM-1457200 Pushrods, Chromemoly, Heat Treated, 5/16 in. Diameter, 7.200 in. Length, Universal, Set of 16
$80.95
$50.69
$21.99
$15.99
NAL-14011051 Guideplate, Flat, 5/16 in. Pushrod Size, Chevy, Small Block, Each
$4.88
chuyz28
Jan 15, 2015 04:14 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
