expected 1/4 times
expected 1/4 times
1997 SS M6 w/ 83,000 miles
spec stage 3 clutch with billet steel flywheel.
pro 5.0 shifter
factory ram air with K&N filter
taylor spyro pro spark plug wires
jet hot long tubes w/o emissions
!egr, !AIR, !cats, !cags
3" y-pipe to a single bullet muffler and dump.
stock 3.42 gears
Throttle body bypass
march under drive pulleys
160* thermostat
descreened maf
Slp double diamond sub frame connectors
hotchkis adj panhard bar
sportline springs
LCA relocation brackets
hotchkis strut tower brace
no spare tire or jack
t-top car with everything in it still
285/30ZR20's on some Z06's
obd1 conversion with tune for all my mods
what do you think i should be running? car has never given me any major problems, runs great.
things i need,
torque arm
lower control arms
pro 5.0 shifter
stock 3.42 gears
160* thermostat
descreened maf
sportline springs
things i need,
torque arm
lower control arms
20's will have to stay, i already sent my ZR1's to GA. I think they weigh more than the 20's do. my 335's were some heavy tires on the 11" wide ZR1's
i'm hoping i could close the gap to the 12's Ive seen some stock LT1 cars run mid 13's.
My previous best time was a 13.84 @ 105 with a 2.0 60', basicly rolled off the line insted of dumping the clutch.
stock slipping clutch, stock shifter, no suspension or chasis mods, just sportlines
longtubes with full flowmaster catback on some crappy 275 kumho's while running at over 200* with 85* outside. with a 160* stermo installed. !cats, !cags, !AIR, !egr, open cycling MAF, it wasnt plugged in and was throwing a code. all of this right after i did the TB bypass mod and it came undone while backing out of the driveway. pouring cooland fluid everywhere like a firehose. and non tuned, stock pcm. car really ran like crap compaired to now. ive got some good tires on my 20's. as long as i hook i think i'll be golden with my eyes on 12's in the near future.
oh yeah, and my track is horrible, it goes uphill after 1/2 way
I'd be best off borrowing some DR from a friend, but not sure who would want to do that for me.
I also have a TA diff cover on the way to help out with the 10 bolt
i hope the weather here in ohio gets better real soon so i can get to the track before i move.
Is Norwalk too far? From what I remember, it's a nice track.
the track is quaker raceway in salem. it was just sold so i dont know if its going to be open this year.
I might head to thompson raceway or norwalk before i move.
i'd like to see what i can run on 20's since thats what i drive on the streets with. but i'll try to get some other wheels with some drag radials on them.
