voltage at solenoid
Old Apr 9, 2007 | 11:59 AM
afr lt1's Avatar
voltage at solenoid
I need to know the voltage at the solenoid when the key is in the crank position. The wire from the ignition key, not the heavy wire from the battery.
If the VATS system is faulty will it show low voltage at this location?
Old Apr 9, 2007 | 12:16 PM
You should see close to battery voltage on the pink wire when the key is in the START position.
Old Apr 10, 2007 | 12:01 PM
afr lt1's Avatar
What would cause low voltage at the solenoid?
Possibly the VAT(theft deterrent) relay???
Old Apr 10, 2007 | 01:36 PM
Could be. It's between the ignition swith and the solenoid.
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
