DLT4001 the good parts for valve cover mounting?
Well i m looking to buy a slightly used DELTEQ kit.It came with everything(coil,wire,wire adapter etc) but the mounting plate was missing.For 375$ for the whole kit,i could deal with it
I already order the dlt4000 billet opti cover.Yeah i like clean install
Is the part DLT4001 the good part number for the valve cover coil mounting brackets ???
Since i got an LT4 with composite plastic valve cover i need some special bolts to mount the brackets.They wrote that the bolts(3) are some M6X1 .So 6mm bolts with 1mm thread.But what about the lenght?How long are they?Anyone knows?
Thank you
Thank you
Well forget ecerything
i was contacted by the seller and there is a lot of missing parts and burnt wire.
The kit 375$ + the mounting plate 60$ (already at 435$ here)+ some additonnal cost to replace the missing opr burnt wire...So he offered me a refund including he 2% fee.Wich was pretty fair.
I spent a little more and bought a brand new kit fom paceperformance(649.95$) and it comes with the optionnal bolts for the compsites valve cover.
i was contacted by the seller and there is a lot of missing parts and burnt wire.The kit 375$ + the mounting plate 60$ (already at 435$ here)+ some additonnal cost to replace the missing opr burnt wire...So he offered me a refund including he 2% fee.Wich was pretty fair.
Jul 4, 2005 05:00 PM
