Who sells complete poly motor mounts?
Who sells complete poly motormounts ready to bolt in and go?
No way in hell I'm spending a day tapering with the stockones.... been there done that.
Do you mean ones that come with the "clamshell"....if so no one makes them... I had about 1.5hours time in drilling the rivets out of my stock mounts taking out the stock rubber cleaning the clamshells, painting them, dropping in the polys, bolt them back together w/ supplied bolts....really easy to do
Yeah, no one makes them ready to bolt on. Find someone who had them on a wrecked car or who put them in and didn't like the vibrations. I could only find a driver's side for cheap, so I'm going with that one poly and the other rubber. That's the one that gets the most stress anyway when the motor wants to torque over.
ive never done motor mounts before but someone suggested since im doing long tubes nows a good time to do the mounts while im in there. i have the energy suspension mounts. i pretty much unbolt the clamshell from the block, drill the rivets and seperate the halves, then put the new mount in, bolt the halves back together, bolt it to the block, and im done? repeat for opposite side?
DrMilhouse
Oct 2, 2002 05:03 PM
