Tune Myself
Tune Myself
Who makes a good tuning and engine mangment program for the computer.... if not how does this work for a tuning tool.. http://www.thunderracing.com/catalog...vid=4&pcid=155
The LM3 aux box
The LM3 aux box
If the T-Pro works the same as the one for my GN it rocks! Will blow a mail order tune away. With the GN one, you install a wideband o2 which interfaces with the T-Pro...then you just program in what AFR you want and the different rpm ranges and loads...same thing for the timing and away you go and it auto-corrects the fueling to match the AFR you programmed in...and its very simple to use. And the Tpro for the GN is MAFless, I suspect the LT1 one is the same so you could do away with that.
Aug 24, 2015 06:41 AM
l
