Tune Myself
Old 03-29-2007, 01:49 PM
CamaroSS8887's Avatar
Tune Myself
Who makes a good tuning and engine mangment program for the computer.... if not how does this work for a tuning tool.. http://www.thunderracing.com/catalog...vid=4&pcid=155
The LM3 aux box
CamaroSS8887 is offline
Old 03-29-2007, 02:07 PM
BUBBA's Avatar
forgettaboutit! Get a mail order tune.JMHO l
BUBBA is offline
Old 03-29-2007, 04:19 PM
2QUIK6's Avatar
If the T-Pro works the same as the one for my GN it rocks! Will blow a mail order tune away. With the GN one, you install a wideband o2 which interfaces with the T-Pro...then you just program in what AFR you want and the different rpm ranges and loads...same thing for the timing and away you go and it auto-corrects the fueling to match the AFR you programmed in...and its very simple to use. And the Tpro for the GN is MAFless, I suspect the LT1 one is the same so you could do away with that.
2QUIK6 is offline
08-24-2015 06:41 AM
sherwinZ28
11
08-15-2015 05:38 PM
RallyRed701/2
07-27-2015 02:55 PM
colts0455
07-24-2015 04:51 PM
Shookiez28
07-23-2015 01:55 PM
Quick Reply: Tune Myself
