LE1 heads with Gm847
I was thinking of going with this combo since I have the cam. Is anyone running this or would I be better off just spending the extra money and pick up the cam he dose with a set of his heads?
True, the Crane springs can handle that lift but the GM847 is going to like a lot of RPM with ported heads so it depends on your car setup.... what gears, tranny and stall are you running around with? Where do you want your powerband to be?
Bret
Bret
The reason I dont want a stall is as of now I only have the stock rear end. And I dont know if it will hold up with out the stall. I know it wont hold up with it.What would be a good shelf cam to go with that would work good with the LE1 heads??
Why not go with the LE1 cam?
Would like to might have to but as of now not in the budget. Might have to save more. I really dont want gobbs of hp. <-- sounds stupid I know. With that hp I dont know how the rear will hold up. Dont have $ 2500 for a 12 bolt.
Then you probably shouldn't be modding your car. Your tranny wont last long once you start modding...
