new best
Old Feb 22, 2007 | 02:09 PM
riodealz28's Avatar
new best Updated **video inside**
i hit a new best of 13.2@102 60"ft 1.858 1/8th was 8.418 with a lil bit of traction problems due to some old used up slicks and this was all motor hopefulley with some new slicks ill get into the 13.0 or mabey a 12.9
heres a vid of my track runs the only 1 thats shows i\in the score board is the 13.5 1 but not the 13.3 or the 13.2
http://video.ls1tech.com/video/4b047...df000719af.htm
Old Feb 22, 2007 | 02:12 PM
2000GTP's Avatar
Nice times for your mods. Throw on an exhaust and hit some 12s.
Old Feb 22, 2007 | 02:13 PM
ZL1modified's Avatar
you need some headers and a catback...:-)
you'll be in the 12's for sure...
^^^ we must have been on the same wave length^^^
Old Feb 22, 2007 | 02:51 PM
riodealz28's Avatar
oops sorry about that i already ahve an exhaust
Old Feb 22, 2007 | 02:54 PM
2000GTP's Avatar
In that case, some better sixty foot times and some weight reduction should net you somewhere in the 12s.
Old Feb 22, 2007 | 02:58 PM
MTBeni's Avatar
Do you have any before and after testing of the 3.73s? Curious because I ran almost the exact times you have with similiar mods, minus the gears. I have MTs now so hopefully I can get some 8.2s this weekend. I only have 1/8 times.
Old Feb 22, 2007 | 02:59 PM
what intake elbow do you have?
if metal i would relocate it down into the CAI...
Old Feb 22, 2007 | 03:30 PM
riodealz28's Avatar
i use to hit 13.8 before the gears and tune i did them at the same and the hit a 13.4 and that was 2.73's to 3.73's
Old Feb 22, 2007 | 03:31 PM
riodealz28's Avatar
Old Feb 22, 2007 | 03:59 PM
i'm assuming you have the stock one...
it is the 90 degree elbow between the throttlebody and MAF sensor...
Old Feb 22, 2007 | 04:15 PM
riodealz28's Avatar
yep i got the stock 1 with the silencer off
Old Feb 23, 2007 | 11:44 AM
'94 Bad A Z28's Avatar
Nice times, your car seems pretty similar to mine before it went under the knife.
My old times were with just a SLP CAI, Yank 2800 converter, and Motive 3.73's on some old beat up Perellie (sp?) street tires so I couldn't get the car to 60' very good but the car still went 13.2 @ 104.9. I think with the mods on your car being so minimal if you went to a smaller converter you'd definitely see some 12 second passes.
Old Feb 23, 2007 | 11:53 AM
jsetzer's Avatar
Nice, I need to get tires eventually. I was in the low 14s at 102. It took my 109 trap to run those times lol.
Old Feb 24, 2007 | 02:44 AM
riodealz28's Avatar
videos posted
Old Feb 24, 2007 | 03:18 PM
mattybz28's Avatar
ls1 front end?
Interesting.
