It Happened
Old Feb 3, 2007 | 11:29 AM
30th6's Avatar
It Happened
i think i cracked a piston last night so its time for a rebuild.im gonna go le2 with a 150 shot on top of that.what all would yall recomend as far as crank,rockers,lifters pushrods,ect. it gonna be a 355 so any help would be appreciated. joe.
Old Feb 3, 2007 | 02:50 PM
slo_z28's Avatar
If your planing on buying a crank and going +.030 anyways, go 383. Its not much more to get a block stroker clearenced. Go Eagle or Scat rods and crank. Crane gold 1.6 roller rockers. I like Diamond or TRW pistons (and look into N20 porting and coatings)
Old Feb 4, 2007 | 11:25 AM
30th6's Avatar
do you think the stock crank and rods will ok? i dont want to spend 1700 on a stroker kit. i was gonna get the block splayed for a 4 bolt to help some.
Old Feb 4, 2007 | 12:54 PM
sssalah's Avatar
Stock crank and rods are fairly strong. Converting to 4 mains and using strong ARP fasteners for the mains and rods will make it strong enough.
I like the comp pro magnum rockers, using the 7/16" ones. As for pushrods using the one comp hi-tech rods.
Old Feb 4, 2007 | 02:10 PM
30th6's Avatar
so the crank and rods will hold 650hp with arp bolts.
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
