best cold air kit
The long tubes won't interfere with your whatever cold air induction kit you choose. I have the Moroso, its a good quality intake and is reasonably priced. You will get alot of varied responses about which intake is the best.
I hate my Lingenfelter one, I can't get it to stay on the MAF very good, every time I try to tighten it down it squeezes out. Part of the problem is my becool radiator pushed my radiator support back an inch or 2 though...
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Anyone know the diameter of the tubing where the filters attach on the SLP for '94+ models? Is it 2.5" as advertized for the '93 model? I'm just curious what the replacement filter options might be. Does the SLP kit come with any sort of tubing for connecting to the MAF?
i really think that are the CAI's out there are about the same, all depends on which one you think LOOKS best..and the K&N is a good kit, you just have to make sure you tighten down that clamp so your filter doesnt fall off
