How many bolts hold on water pump
Old Jan 26, 2007 | 02:29 PM
2tight's Avatar
I'm doing my optispark and would like to know how many bolt hold the water pump on.
Old Jan 26, 2007 | 02:31 PM
lethal93ta's Avatar
6, 3 on each side the passanger side theres one that I normally get with a swivel socket the rest you can get right onto.
Old Jan 26, 2007 | 02:35 PM
Spitfire557's Avatar
If you use a shallow socket, and a long extension, you can get to that one also.
Old Jan 26, 2007 | 02:54 PM
2tight's Avatar
Thanks guys!!!
Old Jan 26, 2007 | 03:06 PM
mrmint69's Avatar
My supercharger just covered one of the bolts so an easy removal was a PITA. I could only remove it 3/4 of the way then it hit the SC unit. Nice design flaw.
Old Jan 26, 2007 | 03:16 PM
lethal93ta's Avatar
my procharger you actually take one of the waterpump bolts out to bolt the supercharger bracket on to there, so you have to pull the hole supercharger and bracket off if you have to get back there.
Old Jan 26, 2007 | 04:14 PM
2tight's Avatar
Success!! now time to pull the balancer can you get one at autozone?
Old Jan 26, 2007 | 04:25 PM
2000GTP's Avatar
The balancer or the water pump?
Old Jan 26, 2007 | 04:55 PM
2tight's Avatar
No I got the water pump off, now I think I'm going to go ahead and change the coil is that a good ideal ? Who makes a good one?
Old Jan 26, 2007 | 05:01 PM
2000GTP's Avatar
I'm a big believer in if it ain't broke, don't fix it. But considering a coil is around 40 to 50 bucks and you are already right there, it is your car. There is alot of aftermarket options from MSD, Accel, and Crane. Another factory Delco coil will get the job done just as well also.
Old Jan 26, 2007 | 05:05 PM
2tight's Avatar
Cool, do you think I should go with a GM Optispark or is the MSD a better unit and is it worth the each cost?
Old Jan 26, 2007 | 05:07 PM
1FstFormulaV8's Avatar
Coils are pretty tough. If it's working fine keep it. Unless you're a firm believer in preventative maintanence.
Old Jan 26, 2007 | 05:09 PM
2000GTP's Avatar
Get the GM optispark for Jason or Dal for three hundred bucks and call it a day.
Old Jan 26, 2007 | 05:13 PM
2tight's Avatar
I was thinking GM also, I found one brand new for $238.00 and the GM water pump for $150.00 does that sounds like a good deal.
Old Jan 26, 2007 | 05:16 PM
2000GTP's Avatar
Yeah, that is a very good deal. I would go for it. Where did you find these at?
