Low/mid rpm misfire
Old Jan 26, 2007 | 12:34 PM
carguy2112's Avatar
Low/mid rpm misfire
I hope you guys can help me out. When I'm cruising around (2-3k rpms) it has a pretty steady miss to it. If I give it any thing more than half throttle, it goes away. It's a 93 Formula LT1 with a hotcam. Its got a new opti, new plug wires, and new icm. I was thinking maybe plugs, but would the miss go away when I got on it if it was plugs?
Old Jan 26, 2007 | 12:45 PM
2000GTP's Avatar
Its possible that the plugs may need to be changed. Another possiblity is th EGR system is malfunctioning.
Old Feb 21, 2007 | 02:01 PM
transAMdriv3r's Avatar
i just solved my problem with a missfire around 2-3k rpms with a new mass airflow sensor and new ac delco O2 sensors. I dont know which one fixed it though.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
