How much slop is acceptable for valve guides?
How much slop is normal for the vavle guides? When I was shimming my springs I could move some of the valves side-side in the guide a little bit. Is this normal? It wasn't anything huge, maybe .005", you could feel it hit each side of the guide.
I'm just guessing and will check my service manual when I get home, but
.0045 comes to mind as a maximum. I'm not sure what the service limit is,
but I'll revise this later once I get home and check.
Oops... revised to correct the number. What's being off by a factor of 10
among friends. DOH! I also did not find anything for an LT1 valve guide
service limit.
service limit.
How many miles are on the heads? Has the motor been running lean?
I would think that the service limit is .003" but I would consider a guide in serious need of replacement after .0025". It is hard to wiggle the valve in the guide and determine what the clearance is unless you have lots of experience with comparing your "feel" to an actual bore gauge reading - I can wiggle a valve and guess within a couple tenths (.0002) where the clearance is at as long as it is between .0005" - .0025, bigger than that just feels loose as your ability to feel the clearance gets more inaccurate the clearance increases.
Some diesel motors use a side wiggle spec - the deflection measurement of how much you can wiggle the valve. I would think that if you can feel movement at the top of the valve with oil in there taking up clearance, that it is something to be looked at - there is power lost in increasing guide clearance.
The more important point is that you should not be wearing guides out to that extent in a EFI motor with less than 100k...there is something causing the wear - too lean, too rich...vacuum leak, exhaust backpressure, all those can lead to guide wear; and as guides wear, the rate of wear increases the more worn they get.
oldschool
Feb 9, 2016 09:21 PM
