Smoke Puffing Out Of Oil Filler
Old Dec 25, 2006 | 08:53 AM
dannyum89's Avatar
Saturday I took my car to the local strip and did a few runs. Suddenly my low oil light came on. I was shocked because I know im not leaking oil since I just changed all seals on the front. I have a slight leak on the oil pan gasket but nothing major. I check the oil and had no oil on the dipstick. When I opened the oil filler cap to put oil in smoke just started billowing out. It seemed to be puffing out in sync with the engine rev. On the way back home it got worst. My PCV hose blew off of my valve cover. Now I have the same smoke comming from the exhaust soon after start up. It doesn't smell like oil or coolant though but it is whitish.
Old Dec 25, 2006 | 09:01 AM
Zeueses 97 RamAir's Avatar
starving
Looks like you have oil leaking check the filter and see how much oil you need, update me
Old Dec 25, 2006 | 09:07 AM
dannyum89's Avatar
Im not leaking oil that bad.
Old Dec 25, 2006 | 09:29 AM
RunRiot's Avatar
Were any of those runs on nitrous? The puffing out the filler cap is a classic symptom of blowby due to a melted piston, or a broken ring land.
Old Dec 25, 2006 | 09:30 AM
Guest47904's Avatar
Guest
Go ahead and do a leakdown test. More than likely you will discover you scratched cylinders and blow by is excessive. You will hear air escaping from the oil fill cap when the test fails.
Old Dec 25, 2006 | 09:32 AM
dannyum89's Avatar
All 3 runs were on nitrous. I was hopping it was just a head gasket. CRAP! Besides, doing a leakdown test on this car is next to imposible. I can barely change the spark plugs. Now you want me to stick a air hose in there!?
Old Dec 25, 2006 | 11:13 AM
OBE1 95Z28's Avatar
Welcome to the cracked ring lands club.
Old Dec 25, 2006 | 11:43 AM
...and, of course, Merry Christmas. Looks like time for a complete tear down.
Old Dec 25, 2006 | 11:57 AM
dannyum89's Avatar
Thanx alot guys!
Old Dec 25, 2006 | 03:41 PM
SS RRR's Avatar
now hold on before everyone starts getting all frantic about a rebuild. it's also possible you only have bad valve guides which would also cause those exact symptoms. as said, do a leak down and also take a spring off of one of the valves and see if you can wiggle the valve stem back and forth. if there is excessive play then your guides are toast and more than likely you'll be having to get your heads redone. regardless it does sound like you will be tearing into the engine...
Old Dec 25, 2006 | 03:46 PM
87lt1rx7's Avatar
::cough cough:: LE2 heads ::cough cough::
Old Dec 25, 2006 | 04:10 PM
89TramsAmGTA's Avatar
Smoke out the breather hole is known as black death for the motor. Like was said above either a broken ring or a hole in the piston. Time for a rebuild.
Old Dec 25, 2006 | 06:18 PM
Guest47904's Avatar
Guest
Run's with no oil forget the NO and you think it's valve guides.
Guess you'll have to explain that one.
Old Dec 25, 2006 | 06:25 PM
396D1SS's Avatar
sounds like blow by to me
Old Dec 25, 2006 | 07:34 PM
93SS's Avatar
Welcome to the wonderful world of cheap Horsepower through the use of Nitrous.
