Cam Sprocket on LT4 Extreme Duty Timing Set..
Old Dec 18, 2006 | 06:46 PM
Meen95z's Avatar
Does anyone have a part number for the cam sprocket only on the Extreme Duty Timing set? Need a new one and dont wanna spend $250 for the whole set.. Thanks
Old Dec 18, 2006 | 07:19 PM
12555885
Unless you already have an ED set, you can't mix it with the other stock components. IIRC, the ED set is a roller type and I know the stock set is a link-belt type.
Old Dec 18, 2006 | 07:37 PM
Meen95z's Avatar
If I look on the gm parts web page, it says the Extreme Duty kit consists of the heavy duty chain and crank sprocket used in the zz 350? I see the one you gave me is different? The ones it gave me part numbers for are 14088783 (chain) and 14088784 (crank sprocket)?
Old Dec 18, 2006 | 08:07 PM
SS RRR's Avatar
3 different parts. 3 different part numbers. he gave you the part number you were asking for.
Old Dec 18, 2006 | 08:14 PM
SS RRR's Avatar
just did a search on this forum for "Extreme Duty timing chain part number"... lo and behold the very first thread:
http://web.camaross.com/forums/showt...in+part+number
Old Dec 18, 2006 | 09:05 PM
Meen95z's Avatar
That dont help me any... if you go on gmpartsdirect.com and type in the p/n for the ed timing set at the bottom of the description it has a p/n for the crank sprocket and timing chain used in the ed kit.. So will 14088783 (chain) 14088784 (crank sprocket) work with the 12555885 (cam sprocket) shoebox gave me? Or is there another timing set out there cheaper than $250 that is good for a mild 383?
Old Dec 18, 2006 | 09:45 PM
Yes, those are the part numbers that makes up the ED set, but maybe cheaper to buy the set (incl the w/p gear) than buy them separately.
Originally Posted by what's in the ED set
Included in this kit are the following steel gears: water pump gear P/N 12551727, a camshaft sprocket, crankshaft sprocket P/N 14088784, and timing chain P/N 14088783.
Old Dec 18, 2006 | 10:19 PM
Meen95z's Avatar
Do you think it is necessary to use the ED Timing set of will a new stock replacement be ok for mild 383? And whats this 12552129 Cam Sprocket?
Old Dec 18, 2006 | 10:55 PM
It's up to you, if you want to use a stock set. Probably ok, if you are not revving it to the moon all the time. If you want the better set, use the ED.
The cam gear above is a non-LT1 cam gear for a regular SBC. It has no provision to run the water pump.
Old Dec 18, 2006 | 11:25 PM
Meen95z's Avatar
Well I run a electric water pump, so could I run the ed crank, chain and that sbc cam sprocket? And the highest it will be reving is 6500-6600.. Any advice thanks..
Old Dec 19, 2006 | 07:36 AM
Javier97Z28's Avatar
Moderator
Run a $79 Cloyes double roller. Better than all other alternatives. Problem solved.
Old Dec 19, 2006 | 08:12 AM
If he had given that info in the beginning, it sure would have saved a lot of trouble. Run the Cloyes 9-3145 and be done with it.
Old Dec 19, 2006 | 08:17 AM
Moderator
Amazing what a little snippet of info given at first will do for a thread 'eh?
AdsoYo
May 2, 2018 03:21 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
routesixtysixer
Jun 23, 2002 02:29 PM
