1 piece or 2 piece rear main seal
LT1 uses the 1 piece like the above post says. I bought a 2 piece seal rotating assembly and used a seal adapter. Don't do this! If you don't get it properly aligned, the seal will leak and the motor will have to come back out and apart to re-do it. If you do happen to get a 2 piece seal rotating assembly cheap, make sure you get a GM PP or a Moroso adapter.
It will be properly machined and will include the dowel alignment pins. Have someone who has done this before help you. Don't go the EBAY cheap way out.
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Dec 4, 2014 11:56 AM
