How did you fix your high RPM miss?
I have seen this as the most common problem on the LT1's. Most people write in here looking for answers and everyone has a list of things to try. What did you finally narrow it down to, if you ever did? I never have. You can even list all the things you tried and how much your into this thing. I have replaced the Opti, plugs, wires, icm, coil, coil wire, fuel filter & fuel pump. Total so far & $700+
I did try unhooking the inline pump and my fuel pressure dropped a few psi. Now the miss is twice as noticable. I guess fuel is a good possibility. I like the idea of the fmu being at fault because it runs great if i take the blower belt off and just run it normal.
What I found to correct the problem (assuming you have LT1 Edit) is to reduce your timing in the 90 and 100 KPA cells (PE) to about 25* or less. And to change the Burst Knock enable temp to 110*C to essentially disable it. My engine was seeing (and probably correctly identifying) knock and pulling timing out. Runs smooth to redline now without any hickup.
From: Austin, TX or Texas State University at San Marcos
I still have a high rpm miss and have run out of ideas myself. Pretty much replaced everything that I can. Only thing left for me to do is the LS1 swap mod it looks like cause I'm giving up.
