stripped header bolt hole, advice?
i stripped out the back bolt hole on the passenger side.. what would be the best way to heli coil it? is there enough room to get an angled drill in there if i remove the header? id like to avoid having to pull the head off... would it be possible for me to lower the engine out the bottom just enough to heli coil it and then put it back in? trying to do this as easily and quickly as possible.. thanks for any help.
SavageZ28
17
Jul 14, 2002 11:04 PM
