Did I get the right gasket kit?
I've been searching all day and I finally found a timing cover gasket kit. I got the FelPro kit, p/n TCS 45956, I hope that this is the one I need. Could anyone let me know if this is the right p/n before I start tearing into it in the morning? I know it'll be just my luck that it won't be the right one. It just seems like the Opti seal looks too big.
That kits is the one for the later model LT vented opti 96-97. Does your 95 have the vented opti?
WD
http://www.cardomain.com/ride/2189634
WD
the vented optis have a shaft about an inch long that goes THROUGH the cam gear, and into the front of the cam, those O-rings go on that shaft, to provide stabalization for the opti shaft
Thank you.
