1994 LT1 into a 1995 V6 Camaro
I currently have a 94 Z28 that has some body damage and i came across a straight body 95 v6 camaro that i can pick up cheap. My question is do i have to put all of my 94 Z wiring harness in the 95 v6 camaro to make it work? I know i am going to have to install the 94 Z engine wiring harness in there to make it work but i am unsure of putting all the inside of the car wiring harness in there. I have done it before and it sucked. Thanks
Re: 1994 LT1 into a 1995 V6 Camaro
I'm in the same boat (94 Lt-1 engine, will be converting optispark to 95 vented version) with a 94 harnes into a 1995 V6 3.4 Camaro.
There are 4 connectors that need to be connected of which 1 is the evaporator sensor (A/C) and plugs right in.
The other 3 (1x blue, 1x black, 1x white) C 210, C220, C230 probably won't connect directly underneath the dash on tha pass side, however the Shoebox website (see my post in the V6 swap topic on top of the page) lists ALL the connector pins and wires so it's a matter of hooking them up to the appropriate wires of the end of the underdash I/P harness i case none of the connectors should fit.
This is pretty straight forward and i'm convinced that with the info at hand it can be connected (soldering, splicing, etc) within half a day.
At this point it's the least of my problems.
Garcia5
Jul 7, 2022 06:51 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
