Engine question.
Old Feb 27, 2005 | 08:08 PM
VickMackey's Avatar
Engine question.
I have something that started this morning with my camaro. When i start it it idles realyl rough almost to the point of dying and i have to pump the gas very hard to get it running smoothly. after about a minute or two it levels out and idles smooth with a few rough hiccups here and there. Any thoughts on what might have started this or what is wrong?
Old Feb 27, 2005 | 08:15 PM
Teufel Hunden's Avatar
Re: Engine question.
Sounds like a fuel problem. Check the pressure regulator.
Old Feb 27, 2005 | 08:28 PM
VickMackey's Avatar
How do i do that? Should i take it do a dealership?
Someone at work told me to put in B-12 Chemtool to clean the fuel lines but i didn't want to until i checked to see it that would help.
Old Feb 27, 2005 | 08:38 PM
If you're not sure how to do it.. a dealer would be best. You have to remove the fuel rails to get it out, which can be kind of a chore. Injector cleaner won't help, because a faulty regulator would be leaking, rather than being clogged. My car showed the same symptoms yours is when mine went bad. It was dumping raw fuel directly into the manifold, and when i shut the car off, it would build up in the manifold and what not.
Old Feb 27, 2005 | 08:40 PM
VickMackey's Avatar
Thank you very much!!
Old Feb 27, 2005 | 10:10 PM
99andMine's Avatar
If that doesnt work you might place the blame on the fuel filter, they do get nasty!! and B-12 is really good for cleaning lines and injectors.
alex5366
Feb 17, 2015 10:43 PM
alex5366
Feb 17, 2015 09:07 AM
Deadbolt24
Jan 19, 2015 01:29 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
derty
Sep 5, 2002 05:01 PM
