2002 v6 3800 leaking?
Old Feb 21, 2005 | 11:08 PM
NewbieWar's Avatar
Well my 2002 camaro seems to be drenched on the floor panel, on the driver side front, and both rear mats are standing in water... what is all this from? its been raining like hell here in cali, so anyone please help me figure the problem, and if anyone would know does warranty cover this?
Old Feb 21, 2005 | 11:37 PM
Pandamonkey's Avatar
Re: 2002 v6 3800 leaking?
Although I would only be guessing at what the problem could be - I can say that as long as you didn't do something like leave the window open, it would definetly be covered by warrenty.
It's possible that the drain holes in the bottom of your door are plugged and the water is not getting out when I runs down the inside of your door..........and enters your car.....
It's also possible that your heater core is leaking and is draining into the car......
Just taking a stab here...
Old Feb 23, 2005 | 10:43 AM
MustangEater82's Avatar
ITs a hardtop?
hmm... might be an issue with your weatherstripping. Your windows close all the way up to the seal right?
If not maybe something wrong with the weatherstripping.
If you want I'll sell you a pair that didn't leak out of a 2000 hardtop v6 Camaro. Were taken out around 43,000 miles.
$60 shipped?(since it might be like $15 to ship them, they are heavier and bulkier then you woudl think.)
I converted to t-tops.
Old Feb 23, 2005 | 08:14 PM
99andMine's Avatar
Just an idea, on some different vehicles the drain hose for the A/C unit comes disconnected leaving a wide open hole that leaks on your floor board.
Old Feb 23, 2005 | 09:21 PM
I willing ot bet its window related if its the front and rear floor boards...
Old Feb 23, 2005 | 11:37 PM
NewbieWar's Avatar
they are manual windows... and they are up all the way.
Old Feb 24, 2005 | 08:08 AM
NewbieWar's Avatar
where are the drain holes?
Old Feb 24, 2005 | 10:10 AM
do you have a hose?
I'd hose the top of the window and see what happens.
Old Feb 27, 2005 | 12:07 AM
NewbieWar's Avatar
well dealer said they cant find anything
so i suppose i will have to look for myself
Old Feb 27, 2005 | 12:13 AM
IF you want to try new weather stripping keep in mind I have a set that didn't leak off a 2k v6 hardtop... only took them off for my t-tops.
Old Feb 27, 2005 | 02:17 PM
No offense to the moderators...
by was this moved form general tech...
This applies to all 4th gen hardtop F-bodies, 93-02.
Not just v6s.
pimpen1024
Aug 19, 2015 08:36 PM
MikeWhitener
Aug 2, 2015 06:17 PM
dolfan324
Jul 17, 2015 10:34 PM
Noct
Jul 14, 2015 01:18 AM
pimpen1024
Jul 8, 2015 09:08 PM
