LT4 Hot Cam / spring question
Hey I have a 305 sbc in my '88 TA and will be getting a pair of LT1 aluminum heads soon with an LT1 intake and I've decided I'm going to get a cam identical to the LT4 Hot Cam but ground on a 114 LSA. Anyways, that means .492" lift with the stock 1.5RRs. I want to pretty much leave the valvetrain on these LT1 heads stock except for the new valve seals I'll put on. Can these heads/springs safely handle that much lift stock, up to 6000RPM? If not, I'll pick up a set of LT4 springs to replace them with.
I'm not really looking for advice towards another cam. I think this combo will make pretty decent power on my 305 and will be even better when swapped onto my 355.
Re: LT4 Hot Cam / spring question
....LT1s have reverse cooling, have the LT1 heads you have in mind been worked to accept normal coolant flow? And that cant be the only difference...
Yes, I know its reverse-cooling and that won't be a problem to fix. The 1.94 valves should also be okay with the 305 as well.. If not for some reason, then I guess its time to throw in the 355...
95chwagon
Jan 13, 2015 09:19 PM
