Brass Gears?
Brass Gears?
Those of you with TransAms or firebirds, have any of you replaced the stock plastic gears in your headlight motors with the brass gears? Did they work? Where is the best place to get them?
Re: Brass Gears?
Yes they work, and yes many people here have used them.
You can also turn the stock plastic gears over 180 degrees and get some more life out of them if you are feeling cheap, if not, shop here
http://www.bfranker.badz28.com/headlightfix/index.htm
Not the standard "shop" type website, but rest assured brent is awesome to work with.
ChrisFrez
Mar 22, 2015 09:12 AM
