cooling problems
cooling problems
my z28 is overheating it has a new radiator but still overheats ,its fine for a little while then it just all of a sudden starts gettin hot but stays cool while driving on the highway,but as soon as i get off and stop at a light or something it just shoots up ! anyone have an idea of what it is , the coolant is full ,dosent leak,and i blead the air out of the system ?
Re: cooling problems
get the manual fan switch from slp because i am thinking your saying when you come to a stop it hits 230 deg if so all our cars do that. until you get the switch you can turn on your heater full blast
You seem to be having the similar problem i am having...
check out this post
http://web.camaross.com/forums/showt...3&goto=newpost
There are some suggestions on there on what you can do...
tomorrow i am draining the engine oil, tranny oil, and the coolant and adding new fluids and maybe install a air foil for the hell of it and ill let you know what the temperature difference is...ill probably throw in one of those
bottles that guarantee to drop down your temperature about 10 degrees...
check out this post
Magenta_Hearts
Mar 25, 2015 10:24 AM
