Will any SBC Cloyes Double Roller work with the LT1 w/electric waterpump?
Old Sep 13, 2004 | 10:27 PM
BlackLT1_TX's Avatar
For example, would the C-3023XSP work if I am running a CSI electric waterpump?
Thanks,
James
If not- which one is the one you have to run?
Old Sep 13, 2004 | 11:02 PM
simple's Avatar
Re: Will any SBC Cloyes Double Roller work with the LT1 w/electric waterpump?
i dont know part numbers off hand but i believe it needs to be for '86 and newer hydraulic roller block SBC's
Old Sep 13, 2004 | 11:06 PM
turbo_Z's Avatar
you need the 3145.
Old Sep 13, 2004 | 11:07 PM
Flyin_Z28's Avatar
Don't know about the C-3023XSP.
The Cloyes double roller set 9-3145 works with the LT1. Another is the rollmaster. You just need to remove the water pump shaft and clearance the timing cover a bit. You might want to do a search because some peopl have issues converting to a double roller.
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
