Will any SBC Cloyes Double Roller work with the LT1 w/electric waterpump?
For example, would the C-3023XSP work if I am running a CSI electric waterpump?
Thanks,
James
If not- which one is the one you have to run?
Thanks,
James
Re: Will any SBC Cloyes Double Roller work with the LT1 w/electric waterpump?
Don't know about the C-3023XSP.
The Cloyes double roller set 9-3145 works with the LT1. Another is the rollmaster. You just need to remove the water pump shaft and clearance the timing cover a bit. You might want to do a search because some peopl have issues converting to a double roller.
oldschool
Feb 9, 2016 09:21 PM
