Popping noise in reverse with wheel turned!!!
Old Jun 14, 2004 | 12:58 PM
crAzy95z28's Avatar
Question Popping noise in reverse with wheel turned!!!
ok only when i go in reverse and turn my wheel either to the left or right it goes pop pop pop pop and sounds like it is somming from the rear? but is it really comming from the front? please help
thanks
randy
Old Jun 14, 2004 | 01:16 PM
n2ceptor's Avatar
MY limited slip did that when it was out ; going in reverse and turning left...
Old Jun 14, 2004 | 02:59 PM
crAzy95z28's Avatar
so what do i do? get a new rear end? or can that be fixed?
randy
Old Jun 14, 2004 | 03:05 PM
crAzy95z28's Avatar
can it be done at home? and can you purchase a limited slip if thats the problem?
Old Jun 14, 2004 | 05:02 PM
crAzy95z28's Avatar
ttt
Old Jun 14, 2004 | 05:08 PM
screamin94Z's Avatar
i have that happen too, mostly after i wash the car or after it rains though doesnt sound like the rearend...
Old Jun 14, 2004 | 05:39 PM
crAzy95z28's Avatar
you sure...it has never done this before....
so it cant be the rain or water!!
Old Jun 14, 2004 | 06:03 PM
442olds's Avatar
check your lower ball joints in the front. I had a poping noise when it was cold and in reverse too, the ball joints were just plain worn out. Changed them and the noise went away.
Also check the rear diff. YOu may need to just change the fluid and add som Limited slip diff addative which you can get at the dealer.
While you have the cover off make sure that the spiders and the shims on the two spiders which ride on the cross shaft are not ready to desintegrate.
Old Jun 14, 2004 | 06:13 PM
crAzy95z28's Avatar
well just had my gears changed....and i had it taken to a shop...
put in new 3.73 gears cuase my other ones got stripped....and im sure thye put in royal purple....
so i dunno.....
Old Jun 14, 2004 | 06:32 PM
442olds's Avatar
I had a set of gears put in a 7.25" G-body diff once with the Abrun Cone type limited slip. They slipped in Royal Purple on me, charged me out the a$$ for it too. I didn't even need diff fluid because I had stuff to go in it.
Anyway, that thing popped like you wouldn't believe. So I drained out the royal purple and filled it back up with the stuff I had bought and put in the GM diff additive and the problem was solved. The Royal Purple is to thick to allow the clutches to slip. At least add the diff addative even though Royal Purple probably states you don't need it with there fluid.
AdsoYo
May 2, 2018 03:21 AM
jj71787
Dec 30, 2014 02:15 PM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
formula79
26
Aug 5, 2002 12:21 PM
