Urgent, Can't get opti seal off!!! How do I get it out?
Old May 1, 2004 | 12:02 PM
96redformula7's Avatar
I am in the middle of changing out the opti seal and the damn POS won't come out. Right now I am wedging a screwdriver in their and trying to pull the sucker out. Any ideas or tools autozone, or checkers would have?
Old May 1, 2004 | 12:24 PM
Got anything with a bend in it to act as a lever? A brake spoon might work (if you know what brake spoon is -maybe not, if you have never adjusted drum brakes ). There is always the seal puller if you have room to get it in there.
You can also try putting something behind the screwdriver to lean on for leverage. It does not matter if you destroy the seal when getting it out, so you can be a little rough with it. Just don't harm the sealing surface or hole in the timing cover. You could try getting on the edge of the metal part of the seal and hammering inward to cave-in the seal toward the center.
It's easier to knock it out from the back when the cover is off, but you should be able to get it out.
Old May 1, 2004 | 12:35 PM
SplitFire's Avatar
I took mine out with a seal puller from Autozone. Came right out.
Old May 1, 2004 | 12:44 PM
I just bought a seal puller, It is like a foot long though, hope I can get in their with it.
Old May 1, 2004 | 12:45 PM
TrouserSnake's Avatar
slowly work your way around in a circle tapping it with a hammer..
Old May 1, 2004 | 12:46 PM
with screw driver on the inside lip.. think of it as a harmonic balancer... it almost has to come out from the middle
Old May 1, 2004 | 01:03 PM
LOOK AT THESE PHOTOS, The lip chipped. AM I SCREWED??!?!?!
http://www.fbody.com/cgi-bin/anythin...i?msgid=525552
Old May 1, 2004 | 03:42 PM
Ken95Z28's Avatar
I don't think so, I think you should be fine.
If you thought taking out was fun wait to you put it in.
Just take your time and slowly tape it home.
Jlo
Jul 29, 2015 03:52 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
