Holley Powershot
Holley Powershot
I'm going to probably switch from K&N to a Holley filter and was wondering if there is a place local that sells them. Best Buy? Mopac? I think I remember someone saying Mopac sells them but that was a long time ago. And do you guys know if I can just keep my K&N filter cleaner kit and use it on a powershot filter? Thanks guys!!!!
There is essentially no difference between the K&N filter and the Holley Power Shot filter. The only difference between the two filters is the color (i.e. K&N = orange, Holley Power Shot = blue). I believe K&N actually manufactures the Holley Power Shot filter for Holley, along with several others for different manufactures. I would just stay with K&N they have been in the business of making reusable cotton filters now for ten years. Also they are the only ones to offer a million mile warranty on their own filters.
Well the reason i am going to switch is because as you know that K&N does not manufacture a filter for the 96+97 SS airbox. The fit of the K&N filter is not perfect and I have heard that the Holley fits well and is also a great filter. So I was wondering where I could pick one up. Thanks guys.
Weird, nobody knows of any places that sell Holley Powershots around here
I really thought someone would have one and tell me where they got it. Iwill have to do some field work myself. Thanks
I know a local (Abbotsford) supplier where I can get Holley power shot filters, but they would have to order it in. Which will take time and there would be a mark-up on it greater then on a similar K&N filter.
I know Mopac WILL sell them...they are a direct distributor of Holley products...
I think a better idea would be to find a K&N or Moroso cold air kit. I have heard there are HUGE gains with that mod over the SS design...ask Musky how his turned out
Andy
Andy
Well if a CAI will show a power increase over the SS airbox then I will think about switching. I will definately look into this. But I think for now and untill I can get a cash flow up I will just look into the Holley.
Why did Musky get a huge increase after he changed to a CAI? Did he get dyno results? Thanks!!!
I have the Holey filter and got it through Lordco.
The main dif is that it is especially made to fit (at least for an LS1 intake), whereas k/n is a half-azz filter with a gasket that doesn't fit that well. So, it is a better fit for ls1's - don't kow bout lt1.
The reason why the colour is different is only becuz of the cleaner - both k/n and holley are the same colour filter, it just goes red if you use the k/n cleaner spray or blue if using holley.
I have heard that the holley cleaning spray is sensor safe so if it gets on your MAF, etc... it won't cause Long term damage, whereas K/N cleaning spray has apparently done so.
Thats about it.
Thats about it.
Thanks Chriss, I appreciate it. I have read that the Hollet's fit is better than the K&N. I guess I will use my K&N cleaner untill it runs out and then pick up the Holley stuff. Thanks!!!
RUENUF
Mar 13, 2016 03:37 PM
