driveshaft end caps
driveshaft end caps
I was putting my drive shaft back in and of the caps came off the end of the drive shaft where it bolts to the rear end, i looked at it has these metal pins laying on the bottom and some fell out... how do i fix this can i buy these caps?
Those are the needle bearings. If you can find them all, just clean them up and put them back in the cap with some grease. Compare that cap to another to make sure you have all the needle bearings in there. I don't think you can buy just the caps, but you can buy a new u-joint.
carguyshu
Jan 22, 2017 11:19 AM
ddr698
Jan 31, 2015 10:58 AM
