how much are injectors?
Can somebody tell me how much are set of injectors. I just need to replace my stock ones. I have a 1994 Z28. Where to get one and what kind of injectors would be good to replace the stock injectors, I do not have nothing done to my car, completely stock. and how much would you guys pay to change injectors labor wise.
thanks in advance.
thanks in advance.
I would probably post in the WTB Forum that you are looking for stock injectors. I would expect to play 50.00 for a set. Also injectors are extremely easy to change so there is no need to pay someone else to change them out.
Thanks for the reply, thats good to know how easy to install.
any installation guide around?
If I wouldve buy a new set of injectors how much are they?, I heared of accel something, is that good for stock car? I kind of wanted to replace it with brand new so I know for sure there is no problem with it. Thanks guys
how much would you guys pay someone to do the injectors swap though?
I went to autozone and ask for a brand new injectors set, but they told me they sell it seperately for about 69 dollars each...ouch! thats too expensive. Is there anyway I can buy a set brand new somewhere else cheaper than that for a stocker.
P.S.
can a bad injector cause vibration (RPM related not speed).
P.S.
About the cheapest you'll find a set of new injectors is, maybe $300. Ive searched around and they are not cheap. Probably cheaper to pull the injectors yourself then take them and have them cleaned proffesionally.
P.S.
P.S.
This is the lowest price I found for stock injectors. And that is each injector
http://www.gmpartsdirect.com/results...umber=17124248
ACC-150819 High impedance, 19 lb./hr., replacement, performance fuel injector set Today $229.95
ACC-150821 High impedance, 21 lb./hr., replacement, performance fuel injector set Today $229.95
ACC-150824 High impedance, 24 lb./hr., replacement, performance fuel injector set
which one should I get from those three? or better yet are those the right one for the Z28 1994? I just wanted to replace the stock ones. Thanks
