how much are injectors?
Old Mar 10, 2004 | 09:04 AM
licerio's Avatar
Can somebody tell me how much are set of injectors. I just need to replace my stock ones. I have a 1994 Z28. Where to get one and what kind of injectors would be good to replace the stock injectors, I do not have nothing done to my car, completely stock. and how much would you guys pay to change injectors labor wise.
thanks in advance.
Old Mar 10, 2004 | 09:12 AM
IDOXLR8's Avatar
I would probably post in the WTB Forum that you are looking for stock injectors. I would expect to play 50.00 for a set. Also injectors are extremely easy to change so there is no need to pay someone else to change them out.
Old Mar 10, 2004 | 10:09 AM
besz28's Avatar
with all the heads and cam swaps you see on here there are alot of people going to bigger injectors,so it should be no problem picking up a used set,i just sold mine for 40 dollars.
Old Mar 10, 2004 | 10:29 AM
licerio's Avatar
Thanks for the reply, thats good to know how easy to install.
any installation guide around?
If I wouldve buy a new set of injectors how much are they?, I heared of accel something, is that good for stock car? I kind of wanted to replace it with brand new so I know for sure there is no problem with it. Thanks guys
Old Mar 10, 2004 | 10:32 AM
LT1Noob's Avatar
I've never had to change them on any of my F-bods....but on my Infiniti, I basically took off the electrical conncetors, and pulled them off the fuel rail. On the Formula, it looks like you basically pull them out. Probably easier/less time consuming than an oil change.
Old Mar 10, 2004 | 10:38 AM
GetaZforgetGT's Avatar
While it is pretty easy...I don't know if its that easy...
Old Mar 10, 2004 | 10:43 AM
licerio's Avatar
how much would you guys pay someone to do the injectors swap though?
I went to autozone and ask for a brand new injectors set, but they told me they sell it seperately for about 69 dollars each...ouch! thats too expensive. Is there anyway I can buy a set brand new somewhere else cheaper than that for a stocker.
P.S.
can a bad injector cause vibration (RPM related not speed).
Old Mar 10, 2004 | 10:51 AM
gamecockfan04's Avatar
About the cheapest you'll find a set of new injectors is, maybe $300. Ive searched around and they are not cheap. Probably cheaper to pull the injectors yourself then take them and have them cleaned proffesionally.
Old Mar 10, 2004 | 11:01 AM
LT1Noob's Avatar
P.S.
I wouldn't pay anyone to do the swap. They are easy to pull. Shop around. I'm pretty sure you can use Ford injectors, even. Chances are that only a few injectors are bad-they may just need to be cleaned. Pull them out, take them to a shop, and they will clean them for you.
Old Mar 10, 2004 | 11:17 AM
This is the lowest price I found for stock injectors. And that is each injector http://www.gmpartsdirect.com/results...umber=17124248
Old Mar 10, 2004 | 11:51 AM
My Red 93Z-28's Avatar
Summit sells Accel 30 lb./hr injectors for $230 a set, and i think the 24 lb/hr are a little bit cheaper, not sure how much though.
Old Mar 10, 2004 | 12:01 PM
IDOXLR8's Avatar
You can also pick up some SVO 24 lb injectors for $200.00 from Summit.
Old Mar 10, 2004 | 06:31 PM
licerio's Avatar
SVO 24 lb injectors are good for stock? how many lbs are stockers, and would it hurt anything to upgrade to SVO 24lb(making it rich) without any mods...? dont know this things sorry.
Old Mar 11, 2004 | 12:31 AM
licerio's Avatar
how much are sets of svo 24 from summit? do they come in a set of 8? thanks
Old Mar 11, 2004 | 12:38 AM
licerio's Avatar
ACC-150819 High impedance, 19 lb./hr., replacement, performance fuel injector set Today $229.95
ACC-150821 High impedance, 21 lb./hr., replacement, performance fuel injector set Today $229.95
ACC-150824 High impedance, 24 lb./hr., replacement, performance fuel injector set
which one should I get from those three? or better yet are those the right one for the Z28 1994? I just wanted to replace the stock ones. Thanks
