gears help , someone answer quick
Originally posted by Jason Dove
Yes, they will work just fine as long as you have a series 3 carrier.
aka, if you have 2.73 gears right now, it's not going to work. if you have 3.23 or 3.42 gears it'll work just fine.
That's only half correct. There's always the possibility that the gears are thicker for the series 2 carrier.
What you need to do is make sure you both have the same carrier. In other words, if both your cars came with 2.73 gears (series 2 carrier), you're ok. If both your cars came with either 3.23 or 3.42 gears (series 3 carrier), then you're ok. You cant swap gears between different series carriers.
It is possible to put series 3 gears on a series 2 carrier if you buy a ring gear spacer, but most people just get the proper gears for their carrier.
that is what happened to me i bought my 373 gears,took out my stock 342 gears,wrong carrier had the shop put old gears back on.returned 373 for the proper carrier 2 0r 3 re install gears 2 weeks later cost me twice as much for install. but you live and learn
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
