gears help , someone answer quick
Old Mar 10, 2004 | 12:37 AM
ddj19852003's Avatar
Im about to buy gear from a fellow member they are motive 3:73 gear he took them out of his 95z i have a 94 z will these gears work for me ?
Old Mar 10, 2004 | 01:12 AM
Jason Dove's Avatar
Yes, they will work just fine as long as you have a series 3 carrier.
aka, if you have 2.73 gears right now, it's not going to work. if you have 3.23 or 3.42 gears it'll work just fine.
Old Mar 10, 2004 | 01:25 AM
a walker's Avatar
That's only half correct. There's always the possibility that the gears are thicker for the series 2 carrier.
What you need to do is make sure you both have the same carrier. In other words, if both your cars came with 2.73 gears (series 2 carrier), you're ok. If both your cars came with either 3.23 or 3.42 gears (series 3 carrier), then you're ok. You cant swap gears between different series carriers.
It is possible to put series 3 gears on a series 2 carrier if you buy a ring gear spacer, but most people just get the proper gears for their carrier.
Old Mar 10, 2004 | 09:54 AM
Jason Dove's Avatar
Motive doesn't make 'thick' gears, the last time I looked anyway.
Old Mar 10, 2004 | 10:00 AM
besz28's Avatar
that is what happened to me i bought my 373 gears,took out my stock 342 gears,wrong carrier had the shop put old gears back on.returned 373 for the proper carrier 2 0r 3 re install gears 2 weeks later cost me twice as much for install. but you live and learn
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
