ran 13.4 at 104.7
ran 13.4 at 104.7
I went to the track about week ago and ran a 13.4 at 104.7 with a 60 ft of 2.09
i ran this with Pacesetter headers, Cut out, 3.73, SLP cold air Nitto Drags. Just wondering how i compare. I think i could do alot better if i could cut down on my sixty foot time
Well just to compare to a stock A4 i'll give ya my times. I run a 13.85 on a basically stock car. It only has a shift kit, 160 thermostat, slp loudmouth qaud center exit exhaust, and PC for less programming. 60ft times for me are about 2.1. I'll let ya compare to that.
Borla cat-backs were available stock (WS6, SS, etc...), programing a stock engine is pointless for hp (although helpful for the shift kit), so besides the shift kit... up "mostly stock" I'd say.
With headers, gears, and nittos a 13.4 is about right. Sounds like its running good.
The 60' time is a bit on the slow side though... I cut 2.0xx to 2.1xx on my 6-speed on a decent launch. Obviously the Street Twin gave me a few good spin-launches (2.5+ yuck
), but I'm sure an A4 should be cutting 1.8's or 1.9's with drag radials.
Nice trap speed for just headers (although I'd wager it'd drop 1 or 2 if you get a good hook at the line)
), but I'm sure an A4 should be cutting 1.8's or 1.9's with drag radials.Nice trap speed for just headers (although I'd wager it'd drop 1 or 2 if you get a good hook at the line)
Also although I'm sure it has happened. I bet it's rare that a stock A4 would hit 1.8 or 1.9 60ft times on DR's. I went from about the average 2.2 to a 2.0 with DR's. I couldn't even come close to any lower than that until the gears and stall started coming. Like I said I'm sure it has happened but getting lower than a 2.0 60ft on a basically stock car doesn't really happen. Just not enough power to get outta the hole yet.
I ran a 13.07 @ 105.8 in a 6 speed convertible z28. Mods I have are mac shorties, air foil,CAI, ignition ( not like the ignition really makes much difference )
Sounds like you stack up pretty well. Nice runs
Mike
Mike
I've ran a few mid 13s at 108 is my best trap. My best et is a 13.4 @ 102 on a 2.1 60'. I have an LT1/T56 in a 3rd gen. Just edelbrock shorties, flowmaster cat back, msd coil and wires, CAI, easy bolt ons.
Yep, did you know that my car came with a Corsa from the factory? I gave it away though, in fact I paid someone to take it. It also came with ram air on a non ram-air hood, and some other things like ummm LT4 heads and intake manifold! Also it came with Jet Hot LT's before they even came out. I also have some programming that I got from madz28.com and noticed a power gain, only because I didn't gain anything
I guess that's why he gaurantees 14rwhp or your money back on a stock car? Yep, programming helps with a shift kit. You're totally right there. Good stuff.....you have 3,800+ posts and don't know what you're talking about.
Amen...Borla stock on SS's and WS6's lol...
Mike
Mike
Wow, that seems VERY quick for a heavy convertible with only shorties and a CAI!
I ran a 13.3 @ 106 with shorties, 4.10s, CAI, LT4KM. I thought that was good.
