Strange knocking sound... (rear)
well ive noticed that behind me there is a weird knocking sound, its not always there and it usually pulsates (sp) when it is there... not exactly sure where it is... over the weekend i replaced 1 rotor and 4 break pads.
Changing fluid in the rear is another awesome fix for noise. My rearend was making the WORST noise you could imagine when I first bought the car. Especially when turning corners. I changed the fluid and put a bottle of limited slip additive and its purrrfect. I've been blasting it for over a year now with 1800 rpm launches on Nittos. I thought it was toast at first.
Another possibility is a bent axel.
Originally posted by Dan Oldham
Could be that the backlash in the rear is off. Put it up on a lift or jackstands, grab the back wheel, and shake it. Normally, if the backlash is off, you'll hear a rattle.
Originally posted by NewbieWar
whats the back lash?
carguyshu
Jan 22, 2017 11:19 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
