Strange knocking sound... (rear)
Old Jan 20, 2004 | 04:14 AM
NewbieWar's Avatar
well ive noticed that behind me there is a weird knocking sound, its not always there and it usually pulsates (sp) when it is there... not exactly sure where it is... over the weekend i replaced 1 rotor and 4 break pads.
Old Jan 20, 2004 | 07:17 AM
Dan Oldham's Avatar
Could be that the backlash in the rear is off. Put it up on a lift or jackstands, grab the back wheel, and shake it. Normally, if the backlash is off, you'll hear a rattle.
Old Jan 20, 2004 | 08:55 AM
scoobysnax83's Avatar
Changing fluid in the rear is another awesome fix for noise. My rearend was making the WORST noise you could imagine when I first bought the car. Especially when turning corners. I changed the fluid and put a bottle of limited slip additive and its purrrfect. I've been blasting it for over a year now with 1800 rpm launches on Nittos. I thought it was toast at first.
Another possibility is a bent axel.
Old Jan 20, 2004 | 10:09 AM
BlackIce's Avatar
Could it be the drivshaft? I get a little pulsating noise and Im gunna swap out the driveshaft and see if thats the problem. I think they have been known to be unbalanced.
Chris
Old Jan 20, 2004 | 10:21 AM
NewbieWar's Avatar
i think its brake related, when i step on the brakes it goes away, but it makes one more thud when i do step on the brakes.
Old Jan 20, 2004 | 10:26 AM
NewbieWar's Avatar
whats the back lash?
Old Jan 20, 2004 | 10:42 AM
Backlash is the how they space the gears. The Sprocket to the Pumpkin. If this is off then it will not seat correctly and could clunk. But I think you are on the right track. It is brake related. Have you taken the wheels off to see if you can obviously see something wrong?
Old Jan 20, 2004 | 10:43 AM
Dan Oldham's Avatar
Backlash is when the gears aren't meshing quite correctly. I've had to get the backlash in mine re-adjusted twice.
Old Jan 20, 2004 | 11:50 AM
TransAm219's Avatar
I know this sounds stupid but are you 100% positive that your wheels are tightened up all of the way
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
