2.02/1.60's on an LT1..do they work?
Are there any probs with running 2.02/1.60's on a stock LT1 bore? I think I remember hearing something negative about this...or maybe 2.02/1.50's. Thanks in Advance
BamaZ28
BamaZ28
Kain did you run those times without headwork? That's almost the exact setup I have minus the cam and I was hoping for impressive times like that. The addition of a CC306 and P&P stock heads will go in this summer.
I picked up 7 tenths and 5 mph from just the cam, and I still have the stock 1.5 rocker arms.
I'm getting Lloyd's heads, 2.00 & 1.56 Ferrea valves, 1.6 RR's, and 30# injectors. I'm hoping to dip down to 11.50's, 11.60's.
I hope I can get near those times with the heads & cam install. How were the ET Streets on your rear? I was afraid to go anything better than DR's until I can get a better rear.
Also as a plug, I'll recommend Lloyd to port your heads. He got them to me in a timely manner, did a damn fine job, and kept in touch with me. An awesome business man. They flowed 272 intake/190 exhaust @ .600 lift. Good enough for what I need my car to do. Not bad for $400 for porting, $200 for machining and assembly, and $220 for the valves.
Not bad prices at all. How long did it take to get em back after you sent them out?
But when it gets around tax time, he'll be flooded with heads and they'll take a while to get back, he said that was one of his busier times.
Just extra props for Lloyd... i've known him for a couple years and he does do damn fine work! He did my head and quite a few other guys i know.... always sweet work!!! When you ready to get a hold of him just throw up a post he's on here....
What's the best way to get ahold of him? Also I won't be needing them done til mid summer.
